Is it possible to use a calendar in a cell?
Princy557
Post by Princy557 »
Hi,
Is it possible to use a calendar in a cell, select a date from it and then just place the actual date in the cell?
If so , how?
Regards
Princy557
robert-l
Re: Is it possible to use a calendar in a cell?
Post by robert-l »
Do you mean something like Insert - Form object - Listbox ... ?
Princy557
Post by Princy557 »
Hi,
thanks for the reply
Well possibly, but using a calendar (month) where once you have selected the date it shows as a normal 15/03/2019 type.
Wonder if it could be done in BasicMaker, I'm not skilled enough to do that.
Just to get it across
you select a cell and a months worth of caledar pops up, you select year, month and day. than tht cell shows up as a standard date format.
It could very well come from the Insert/Form Object/Calendar Entry ???
Does it make sense what I'm trying to do?
Regards
Regards
Princy557
robert-l
Post by robert-l »
We currently don't support that, but I will forward your idea to product management.
Giri
Post by Giri »
Hi,
I am trying to paste excluding the hidden cells (which is normally done in MS excel using Alt+;). How can I sort this??
Giri
Post by Giri »
how can I do data validation in plan maker? Dropdowns...
and how can I paste values excluding hidden cells..
Princy557
Post by Princy557 »
Just thought I'd ask if there was any move towards getting a date dropdown into a cell?
2019-2021 it's been a while.
Regards
Princy557
No, currently this feature is not available, but I have forwarded this request to our product management...
Princy557
Post by Princy557 »
Did that not happen in March 2019?
I would have thought it quite a useful function of the spreadsheet.
Ah well, we can live in hope.
Regards
Regards
Princy557
