Combining multiple prdx files
darren7734
Post by darren7734 »
Has anyone got any suggestions for the easiest way to combine multiple prdx files? I'm looking for a method easier and less time consuming than opening multiple files and then copy and pasting them into one new project. It would be good if there was an option similar to using video editor software where you could create a project and drop individual prdx files into a timeline to create one ultimate presentation.
Re: Combining multiple prdx files
Post by sven-l »
An easier method is on the wish list for the future but not yet available.
On the Home ribbon tab, press Add, then "Slides from presentation". This lets you at least insert one file after the other, without open/close/copy/paste.
Return to “Presentations 2018 for Windows”
