Insert > Photo album
txt
Post by txt »
If pictures are added via the 'Photo-album' wizard as embedded link ('Save pictures in document' has not been ticked), Presenter will not remember the original path.Next time the presentation is opened it will request to look for the 'missing' file, i.e. 'The external file "..." could not be found or is invalid.'
Note that the pictures are note located in the same directory to where the presentation is stored.
Michael Uplawski
Re: Insert > Photo album
Post by Michael Uplawski »
Confirmed.
This malfunction and the obligation to store images in the document defy the whole purpose of the wizard.
There are flatworlders all around the globe. (unknown author)
If we go now, nature may stand a chance. (known author)
Post by sven-l »
I tested it with rev.946.0213 64bit and the Nightly version and the option "Save within document" was set. Which Linux and which desktop (Gnome, KDE, etc.) are you using?
Michael Uplawski
sven-l wrote: Mon Mar 11, 2019 12:01 pm I tested it with rev.946.0213 64bit and the Nightly version and the option "Save within document" was set.
The problem occurs, when the option is NOT SET.
robert-l
Post by robert-l »
We will check what´s the matter.
Return to “Presentations 2018 for Linux”
