Occasional Cel Left Alignment Issues
clifford949
Post by clifford949 »
Sometimes the text or numbers won't fully left align. The data isn't centered but it is just a tad bit to the right. If I copy the data and paste it into a different cel it aligns fine. Then I've been moving that cel into position as a work around. This happens if I copy the whole cel and paste it in a new location but it also happens if I type in a new cel.
I verify all alignment is correct. The settings in alignment look the same in a cel that is not acting up. This only happens occasionally but would like to know how to fix it when it does happen.
Thanx !
Re: Occasional Cel Left Alignment Issues
Post by sven-l »
Please provide a sample file (send it to forum(at)softmaker.com referring to this thread). Thank you!
