Hi,
I would like to enter new words into Macedonian dictionary through Spell Checking option, but it always switch to Russian. How can I set the Macedonian user dictionary to be default?
User Dictionary
User Dictionary
Dell Inspiron 7559 i7
Intel Core i7-6700HQ (3.50 GHz, 6M )
16GB Dual Channel DDR3L 1600MHz (8GBx2)
1TB HDD + 128 GB SSD
UHD (3840 x 2160) LED- Backlit Touch Display
NVIDIA GeForce GTX 960M 4GB GDDR5
Windows 10 x64
SoftMaker Office 2018
Windows 10 x64
Re: User Dictionary
Do you mean that in new files you create, there is always the Russian spell checker active? Or after you saved and re-opened your file, suddenly the dictionary changed to Russian?
