Hi all,
Just getting started with Planmaker, so please bear with me.
I want to have a cell display the day of a week next to the date.
However the date format is MM/DD/YYYY whereas I want it to be DD/MM/YYYY
Is there any way to manually add a specific date format?
Thank you for helping out!
Planmaker - day of week - howto display?
Re: Planmaker - day of week - howto display?
Are you using the Windows version? Your screenshot looks like you're on a Mac. Which date format is set in your Windows/Mac settings? PlanMaker usually uses the same settings.
- SoftMaker Office 2021
