Document Formats for Envelopes
Robin Holt
There seems to be some pretty peculiar behavior when envelopes are saved in different formats. A standard #10 envelope saved in .tmd or .tmdx formats is saved correctly. If the same envelope is saved in .doc, .docx or .odt, Textmaker automatically adds a header and a footer, which frankly don't make much sense on an envelope. Is there a bug here or have I missed something?
Re: Document Formats for Envelopes
Please attache a sample file (in tmd or tmdx file format) or send one to forum(at)softmaker.com referring to this thread. Thank you!
Robin Holt
My apologies for not following up in a more timely fashion.
The attached file is an exemplar #10 envelope of the size and format used typically in the U.S. This file is in .tmd format and can be saved and retrieved without problems. The file was originally created using the envelope tool included in Textmaker.
If the file is saved in .tmdx format an unwanted header is automatically created.
If the file is saved in .doc or .docx formats, an unwanted header and unwanted footer are automatically created.
If the file is saved in .odt format, the contents disappear.
I'm currently running service pack 944.
- Test envelope 1.tmd
- (14.43 KiB) Downloaded 4032 times
I can confirm this issue with your sample file and will report it to the developers.
