Two How To Questions...
chuxter
Post by chuxter »
1. Is it possible to make the lines around cells either white or transparent? How?
2. Is it possible to include column and row sizes when copying a sheet to another sheet? How?
TIA...
Re: Two How To Questions...
Post by sven-l »
chuxter wrote: Mon Jan 14, 2019 4:47 am 1. Is it possible to make the lines around cells either white or transparent? How?
No, but you can completely disable the sheet grid in the menu ("View").
Post by sven-l »
chuxter wrote: Mon Jan 14, 2019 4:47 am 2. Is it possible to include column and row sizes when copying a sheet to another sheet? How?
No, and it doesn't work in MS Excel 2019 either.
chuxter
Post by chuxter »
Thanks Sven-l...
I looked through the choices in "View" and didn't find "sheet grid". I need a bit more help.
chuxter
Post by chuxter »
There are many things that don't work in MS Excel. They caused me to look for a substitute. Don't be so myopic!
In a spreadsheet, all cells in a row share the same height. All cells in a column share the same width. I think it would be quite surprising to a user if pasting something changes the height or width of totally unrelated cells.
chuxter wrote: Fri Jan 18, 2019 5:20 pm Thanks Sven-l...
Go to the View tab of the ribbon and uncheck the checkbo "Show sheet grid".
