Preserve cell formatting in pivot table - Linux [SOLVED]
Klaas Vaak
This feature does not seem to work, even though the box is checked in the pivot table settings. The same actually applies to Autofit column width.
Re: Preserve cell formatting in pivot table - Linux
Please send a sample file to forum(at)softmaker.de.
Klaas Vaak
Done - see your inbox.
Klaas Vaak
Sven, have you been able to have a look at the file I sent?
Re: Preserve cell formatting in pivot table - Linux [SOLVED]
Yes, thank you!
