Saving an imported CSV or TXT file as XLS
When I open a CSV and make a change, an asterisk appears after the filename in the tab . When I save the file using the default name (I have XLS as my default file type), the asterisk does not disappear. The same happens with a TXT file.
Re: Saving an imported CSV or TXT file as XLS
The asterisk means that you have made changes since you opened the file. When you save the file (even when you save in another file format) there should be no asteriskas the file has been saved and no changes have been made.
