Protect cel's individual
Karstv
Post by Karstv »
Hello,
I have a problem with planmaker. I have made a cashbook file. I want to protect some cel's from writing. But when i protect them and safe the file and reopen then the protection is on more cel's in the sheet...
1 i choose the cel's to protect
2 with the mouse i choose: protect cel and formula
3 then I protect the sheet (no password)
4 I safe the file
5 I open the file
6 Some normal cel's are now also protected
So what am I doing wrong here? I tried different methodes. The only solution for now is to use no protection or get another spreadsheet-program?
Re: Protect cel's individual
That's because it doesn't work that way. By default, all cells are protected - just with global protection inactive. You then select the cells you want to unprotect and deactivate cell protection for them, then activate sheet protection. Please check the relevant chapter of the PlanMaker manual.
Karstv
Post by Karstv »
Working now! Don't know why. I tried it after the windows 10 upgrade. Magic....
