Can't delete a column when autofilter is enabled
galanta
Post by galanta »
It appears that this behaviour is not a bug but probably the way it is designed to work. I am wondering if there is a way to do it without disabling autofilter. Has anyone come to the same problem?
Re: Can't delete a column when autofilter is enabled
Post by sven-l »
You are right. I can confirm this issue in PlanMaker while I can properly delete the same column in the same file in MS Excel. I will inform the developers.
mistrowl
Post by mistrowl »
Sorry for the necropost, but does this issue have a solution yet? Encountering it myself.
No, but I have forwarded the details again.
