embedding a variable
Princy557
Post by Princy557 »
HI,
Second topic all to do with pmdx file.
Is it possible to embed a variable in a pmdx
I have a pmdx held on my desktop, depending on which computer I use this pmdx is it possible for it to say 'this pc uses drive: and folder Y based around the computer name?
Hope that makes sense.
Regards
Princy557
Re: embedding a variable
Post by sven-l »
You mean you want to use links with relative paths in the files?
Princy557
Post by Princy557 »
Sounds right,
but relating to the computer I'm actually using. Paths might be different on different PC's
Regards
Princy557
