Suggestion: More Colors
ITFlip
Post by ITFlip »
Hello,
I'd like to see a few more color options for the User Interface, specifically green or blue. There could also be options to select a user-specified custom color and/or an option to use current system colors.
For me, some colors are more readable than others, or provide less eye strain in specific lighting situations. Within a user interface design I appreciate having different colors or different shades of color for the Title Bar, Active Tab, and Inactive Tabs, as you do with the default Ribbon Interface colors of red, grey, and dark red.
Thanks!
Phillip :D
Re: Suggestion: More Colors
Post by sven-l »
Thank you for your suggestion. I will refer it to the product management.
