What is correct setting for Planmaker ?
Date format
Date format
I must have the standard Europe date format dd/mm/yyyy or DD MMMM YYYY, but get it only when I type it in as USA format. Standard format date import goes complete wrong.
The Locale set in KDE is dd/mm/yyyy
- Michael Uplawski
BUG: Date format
Difficult to say, as the setting does not work. It would be correct, if PlanMaker honored its own announcements, sometimes.
Screen Shot with an authentic cell format. This can be called a bug (continues below the picture): I may be erring, but think that this had been a reported issue before the current releases 936 or 938. What is worse: Any attempt to overwrite the current date-format by a user-defined format fails just as well: Have a laugh, all, if this is funny.
“There are flatworlders all around the globe.” (unknown author)
“If we go now, nature may stand a chance.” (known author)
