Error in TM manual on page 26
VLMin
Post by VLMin »
In Tip #3, the User Interface button is located in Tools > Options > Appearance, not in Tools > Options > View. Also, in that same tip, "Tools > Option" should be "Tools > Options" ("s" on the end of "Options).
Re: Error in TM manual on page 26
Post by sven-l »
Tip #3 is located on page 31 in the English PDF manual and it states:
Tip #3: You can switch the user interface between ribbon and classic menus and
toolbars at any time. To do this, invoke the menu command Tools > Option (or,
in the ribbon, the command File > Options). In the dialog, switch to the
Appearance tab and click on the User Interface button. A dialog box appears in
which you can select the type of user interface you prefer
I think this is correct but I will report the typo. Thank you!
