Keyboard shortcut to switch between tabs?
VLMin
Post by VLMin »
Is there a keyboard shortcut to switch between tabs? Many applications use ctrl-tab, but TextMaker just seems to insert a tab character when I use that combination.
Re: Keyboard shortcut to switch between tabs?
Ctrl+F6 and Ctrl+Shift+F6
VLMin
Post by VLMin »
Thank you. Those are two-handed shortcuts for a very common action. Is there a way to modify them, or to add a second shortcut such as ctrl-tab, where ctrl-tab toggles between the current tab and the most recent tab? In my experience, this is a very common usage.
In the alternative, would the dev team be willing to add ctrl-tab (since it's not being used for any apparent purpose, and since it's the virtually universal solution to this problem) to toggle as described above?
PS: I would add that this solution would provide the best of both worlds, sequential and toggle tab switching.
You can assigns these actions to any key combination by customizing the keyboard mapping.
Note that Ctrl+Tab is already in use (TextMaker: insert a tab inside a table cell; PlanMaker: switch between sheets). You can override these, but then you cannot access their original function anymore.
VLMin
Post by VLMin »
Thank you, Martin. Given my desire to create a toggle effect, what action(s) should I customize?
There is no toggle, only fwd/back.
VLMin
Post by VLMin »
Yes, thank you, I see that. I am requesting/suggesting the addition of a toggle capability, as that suits many people's working style (my own included, of course).
