Zoom levels
VLMin
Zoom levels
Post by VLMin »
In TextMaker, is it possible to modify a preset zoom level and/or add to the list of preset zoom levels? (There are 9 configurable percents in FlexiPDF, going up to 1600%, which can be most useful for positioning tweaks.) Currently, we see 50, 75, 100, 125, 150, 200. When working on a project, it is often useful to toggle between two preset zoom levels of our choosing, e.g., 38% and 92% (arbitrarily chosen here) instead of, say, 50% and 75%. Having to use the dialog every time is quite cumbersome and slow. It would be much better if we could establish and retain,modify our own presets, then use configurable zooming shortcuts to move between/among them — no mouse, no dialog box.
Also, what are the minimum and maximum supported zoom levels? (How small and how big can one go in TextMaker?)
Re: Zoom levels
Post by sven-l »
There is no way to store custom zoom levels in the list of presets. Your current zoom level will be stored in the document.
VLMin
Re: Zoom levels
Post by VLMin »
Okay, thanks for your response. I offer this as an enhancement request, then. Have a great day!
Re: Zoom levels
Please share the default template file on which you did this desired modification.
Also, as your problem is with SoftMaker Office 2021, please continue on that forum as multiple but the same posts in different threads make confusion and problems.
