cannot save
knightgogo
cannot save
Post by knightgogo »
Hi, when ever I want to save file in text maker 2018, an error message: backup file cannot be created. Call up the "option" dialog and check the backup folder on the dialog sheet "files"...and when I click on "option"..nothing happen...that is no response when I click on "option"..HELP
Re: cannot save
Post by sven-l »
Does TextMaker not react anymore when you click on the "Options" button? If yes, try to install SoftMaker Office gain. does it help?
In the Options under the tab "Files" you can disable the backup files or enter another backup folder.
knightgogo
Re: cannot save
Same error, even after reinstalling.
Txt maker not react on 'options' button.
Re: cannot save
Post by sven-l »
knightgogo wrote: Wed Oct 03, 2018 8:31 am Same error, even after reinstalling.
Please rename the folder "Settings" in C:\Users\NAME\Documents\SoftMaker (e.g. in "Settings2"). Does it help?
