Hi everyone
I have created a document and saved it as docx format. When I try to create a New document with the New function or Ctrl + N, the same previous document appears again and again and I can't create any new document. I do have a correct licence for this software.
Has anybody get this bug ?
New document impossible to create
Re: New document impossible to create
It seems like your have overwritten the Normal.tmvx (default template). Every new file you create via CTRL+N will be based on the Normal.tmvx.
Solution: Check your template path in the settings (in the "Files" tab). Here you can find your templates and change the Normal.tmvx.
- SoftMaker Office 2021
