Character Styles Combo box
jolugaju
Post by jolugaju »
Hello!
I wanted to know how to have a Character Style Combo box like the one there is for Paragraph Sytles (in the Formatting bar).
Is it possible?
If not, is there a possibility to make a request for it?
Is there another way to know always what Character style corresponds with the cursor position?
Thanks in advance!
Edit: I made a mistake. This post should be in the TextMaker forum.
I don't know how to move it.
Re: Character Styles Combo box
Post by sven-l »
There is no combo box in the ribbon available for character styles (only the regular dialog box). But you can use the sidebar.
jolugaju
Post by jolugaju »
Yes, I've seen this feature in the sidebar but since there's one combo for Paragraph styles and works great it would be nice the possibility to have another one for Character Styles.
Thanks for your answer!
