Does not print the contents of the .doc file if it is in a table.
atbtbcs
Post by atbtbcs »
Sorry, I'm using a translation program. The next is my problem. I opened a .doc file with a table and text fields. When printing, you only print a blank page and see nothing in the print preview. If I convert the table to a nested object by a right click (hopefully translated by google) then I can print the text. But then I have to go back to wanting to type or improve a new text because I do not see the lines in the table. This LO is solved, but your program is better for you so I would like to use it. Thanks
raitis.veksejs
Re: Does not print the contents of the .doc file if it is in a table.
Post by raitis.veksejs »
To reproduce an find solution of the problem we need step by step description what are you doing and sample file. You can send it by using personal message or submit through our support desk.
