Using SoftMaker Office 2018 Rev. 928.
Checked for updates and found there is a new update.
However, when I try to update I receive error: Failed to get data for 'CurrentMajorVersionNumber'.
Clicking 'OK' closed the dialog and the downloader runs with 'Connecting...." as status and never updates.
Any suggestions?
SoftMaker Updater Tool not working
- Contact:
Re: SoftMaker Updater Tool not working
Most likely you are using Windows 8. The updater had a bug that caused it to work on every version Windows except for Windows 8.
Please download the latest full-version installer again and install from that:
http://www.softmaker.com/en/softmaker-office-download
This gives you the latest SoftMaker Office, including a compatible updater.
- SoftMaker Office 2021
