I noticed that the "Use automatic hyphenation" check from the Language settings of TextMaker is not persisting within restarts of the application.
Steps to reproduce:
- Open TextMaker Options, go to Language tab
- Uncheck "Use automatic hyphenation" (my setting is checked right now, I cannot undo it to test the other way)
- Click OK to save the settings
- Close TextMaker
- Open it again and see that the setting did not save itself.
Automatic hyphenation setting not persistent
Re: Automatic hyphenation setting not persistent
Hyphenation is not a global option (like all the other options in that dialogue). Hyphenation will be saved in the current document and you can have it either enabled or disabled in every document. I will ask the developers if they can add a hint to that option that it is only stored in the current document but not in the program.
I understand, sven-l. Thank you for clarification!
