Key Bindings - Mac/Win
Richard Huneger
Post by Richard Huneger »
WIth preferences set to NOT use Left-Alt for Shortcuts, the cursor movement, select function, and scroll function, for TextMaker as shipped are indicated in the attached PDF, versus the Standard Mac keybindings.
Desirable, to cut confusion for regular Mac users, would be an option to set the keybindings to "Standard Mac" -- I don't know if they bindings involving the Ctrl- key are standard Windows or not.
TM-Keybindings - Mac 2018.pdf
(358.29 KiB) Downloaded 5201 times
Re: Key Bindings - Mac/Win
Post by sven-l »
Thank you! I will refer your table to the developers.
Return to “TextMaker 2018 for Mac”
