Is possible to install 64 bit version along with 32 bit version ? I wish use BasicMaker and I have problem with Enable40_64.dll .
Thank you.
64 bit along with 32 bit ?
- jimjutte
- SoftMaker Volunteers
- Contact:
Re: 64 bit along with 32 bit ?
Before you do anything, I suggest that you see if you can run each one. That is, install 32-bit in a custom folder like SMOffice-32 and see if it works, if it does, then I suggest uninstalling it and they install SMOffice-64 in the same manner and see if it works. If it does, reinstall the 32 bit version into the other folder. I can't obviously guaranteee it, but I would be surprised if it didn't.
Hope that helps.
Hope that helps.
Cheers
Jim
Jim
Hello and thanks for the reply.
I already installed SoftMaker 64bit on "C: \ Program Files".
So I installed SoftMaker 32bit on "C: \ Program Files (x86)" .. and the installer deleted 64 bit version on "C: \ Program Files".
Not problem: I will use 32-bit version. When 64-bit version will be ready, I will reinstall the x64 version.
Thanks for the attempt!
- jimjutte
- Contact:
Yes, it would if you didn't create separate folders.
Anyway, if you're happy, that's great.
Cheers
Jim
Jim
