Open Powerpoint in Slide Show Mode.
Is there a way to open a powerpoint and start the slide show automatically. With MS Powerpoint I would use the /s.
- jimjutte
- SoftMaker Volunteers
- Contact:
Re: Open Powerpoint in Slide Show Mode.
Perhaps I don't understand. You can load timings for the show and have it loop. I haven't use MS PPT in a long time, but I'm not sure how you would have the /s, unless you mean from the cmd window?
Cheers
Jim
Jim
You can use the ppsx file format. If you start such a file via double click (or right mouse click=>"open with"), Presentation will open the file and automatically start the presentation.
