Hi
Is it possible to make Textmaker choose RTF as its default file format when saving new documents? I have years worth of RTF files, and I like the consistency.
Thanks!
Default format for files
Re: Default format for files
HI.
Go to Tools>Options>Files and select Default file format.
The option for .rtf is at the bottom of the list.
Select it and Textmaker will save in RTF format by default.
- SoftMaker Office 2021
- FreeOffice 2021
