Uninstall Freeoffice
realdeivid
Post by realdeivid »
Hi everybody.
I want to uninstall freeoffice 2018, but i don't know how.
I install with root in manjaro with the .tar file
Re: Uninstall Freeoffice
Post by sven-l »
Please use the following commands in the shell to install/uninstall SoftMaker Office on your machine (please replace the names of the files and installations with the correct ones):
Unzip: tar xzf softmaker-office.tgz
Install: our script (./installsmoffice)
uninstall: our script (./uninstallsmoffice)
mrouilla51
Post by mrouilla51 »
I have the same issue. I want to uninstall version 2018 (Manjaro) but there is no "uninstallsmoffice" script in the softmaker-office-2018-976-amd64 archive ??? How do I do it ?
You have to search "uninstallsmoffice" script in the installation folder of SoftMaker Office 2018 where you installed it. Please check again.
doclight
Post by doclight »
SuperTech wrote: Sun Jun 07, 2020 8:31 pm You have to search "uninstallsmoffice" script in the installation folder of SoftMaker Office 2018 where you installed it. Please check again.
Hi, same issue on fedora 32. I cannot find uninstallsmoffice, even in the folder where freeoffice is installed. I installed it by downloading .rpm file and clicking on it.
I don't want to be unpolite, but I'd like to buy the full version and if you don't provide a solution you are going to loose a customer or even a client.
The uninstallsmoffice script is only available (and only makes sense) if you installed our Office using our .tgz installer.
If you install using RPM, DEB or the Arch Linux / Manjaro installers, you need to use the tools of the respective package management to uninstall the software.
doclight
Post by doclight »
Thanks, in my case it is
Code: Select all
 sudo dnf remove softmaker-freeoffice-2018
