A minor issue, but it would be great if that could be fixed some time in the future
can't save file with ä or ö in filename
Makes me remember the good(?) old days of MS-DOS 3.3
Re: can't save file with ä or ö in filename
1. Which Linux distribution are you using?
2. What is the system language of your Linux?
3. Does it work better with LibreOffice?
4. Which revision of SoftMaker Office is installed (Help=>About)?
Also, please provide the log file sminfo.txt (Help > About > Write system information).
Textmaker18 rev 931.0518 64 bit on Slackware -current, system language en-US, default document language in TM: Swedish
This issue seems to be linked to the one in this thread: viewtopic.php?f=305&t=17751
In order to get accents to work properly I've added the line export LANG=sv_SE.UTF-8 to the /usr/bin/textmaker18 file. However, if i delete that line I can save files with ä or ö in the filename.
Since the accent issue will be fixed in the next service pack, I guess everything will be sorted.
Cheers.
Cheers.
- sminfo.txt
- (211.95 KiB) Downloaded 5292 times
- Contact:
And what happens when you save a file with a special character? An error message? Which? Or does the file name look "funny" in your file manager?
I can add most special characters to a filename, e.g. + $ # @ ( ) ? !
A few give the message "invalid filename", e.g. £
Please wait for the next service pack (rev.933) and review this issue with it.
I'm sorry having to report that after upgrading to latest buld 933, the problem still persist.
As mentioned here:
I can't get accents to work properly without adding the line
export LANG=sv_SE.utf8
to the start script, and with that addition it is not possible to save files where the filename contains the letters å, ä, ö ("Invaldid filename"). Other special characters work, though.
As mentioned here:
There is still a trouble ticket open (38419) for your problem. We will inform you as soon as we have more information.kgha wrote: Mon Jun 25, 2018 12:54 pm I'm sorry having to report that after upgrading to latest buld 933, the problem still persist.
As mentioned here:
It seems that the issue happens only on your system. No other customer reports that problem. Also, we couldn't reproduce it here with the same Linux. Something with your system is not quite right.
As a solution it would be best if you configure your system using a Swedish UTF-8 locale. These days a Linux system should always be Unicode-enabled.
Saving a file with filename containing å/ä/ö letters works for me on rev 933.0619 on Arch. Can't remember have I tried to save a file with filename that contained these letters before this revision.
Code: Select all
$ locale -a
C
en_US.utf8
fi_FI.utf8
POSIX
Code: Select all
$ echo $LANG
en_US.UTF-8
Setting system locale to LANG=sv_SE.utf8 doesn't solve this issue. And for various reasons I prefer English as system language. So I have to choose one of two options:
1) Running en_US as system locale and writing in Swedish on Swedish keyboard - then I can use å,ä,ö in filenames but accents won't display properly, or
2) starting Textmaker with
Since I normally avoid these letters in filenames, I stick with the second alternative. As said in my first post, it's really a minor issue.
which solves the accents issue but prevents me from saving a file with å,ä,ö in the filename.export LANG=sv_SE.utf8
textmaker18
- Contact:
If you prefer English, you can replace sv_SE.utf8 with en_US.utf8 or en_UK.utf8
As I didn't mention in my previous post, I have system language in English and keyboard layout is US. å,ä,ö are displayed correctly. Note that I have binded å,ä,ö (and €) via Xmodmap to the keys as they are in Finnish layout.
Yes, with system language en_US and starting Textmaker with textmaker18 and nothing else, I have no problems with using ä or ö in filenames. But (as I mentioned in post #3 in this thread) this issue is linked to the one discussed in another thread: viewtopic.php?f=305&t=17751
With system language en_US, the words "crème fraîche" appears as "cr`eme fra^iche" and Düsseldorf (writing the German letter ü on a Swedish keyboard is done with " + u where the trema is a special character different from the double quotation mark) appears as Dusseldorf.
A workaround is to change locale for textmaker:
I've done that by adding the export LANG line to /usr/bin/textmaker18
Then accents appears correctly (which is important for me), but I can't save a file with the letters å,ä,ö in the filename (not particularly important). I can, however, open a file where the filename contains these letters, and save it under the same name.
Same or similar problems affect other programs if started with preceding "export LANG=sv_SE.UTF-8" (e.g. Avidemux and Gimp) while other works (e.g. OpenOffice, Audacity).
A month ago, sven-l wrote in the other thread that "The problem with accented characters is solved now and should no longer occur in the next service pack." I therefore expected that updating to 933 would allow me to ditch the "export LANG=sv_SE.UTF-8", but the accent problem was not solved after updating.
Code: Select all
textmaker18Then accents appears correctly (which is important for me), but I can't save a file with the letters å,ä,ö in the filename (not particularly important). I can, however, open a file where the filename contains these letters, and save it under the same name.
Sorry, I must have missed the accents issue. Them seems to be issue for me too, I'll drop a message in the thread which you linked.
However, I can save files with å,ö,ä no matter is the LANG set to en_US.UTF-8 or fi_FI.UTF-8.
