Hi,
Softmaker 2018 for Linux (system info file is attached).
Pressing Esc while editing any cell with Accounting format (other than $), renders the program unresponsive for a few seconds (10 or so).
Steps:
- Select a cell with Accounting Format (other than $)
- F2 to edit.
- Press Esc.
- Program unresponsive.
PlanMaker Unresponsive
- sminfo.txt
- (316.04 KiB) Downloaded 5659 times
Re: PlanMaker Unresponsive
What I did (PlanMaker rev.931.0518 64bit in Kubuntu 18.04 64bit):
1. Open PlanMaker with a blank, new sheet
2. Format A1 in accounting (€) cell format
3. Select A1
4. Press F2
5. Press Esc
=> No delay. PlanMaker is not unresponsive here. Which currency exactly have you chosen for the accounting cell format?
3. Select A1
4. Press F2
5. Press Esc
