Hi, I'm evaluating Flexy PDF and I need to add a watermark or a label into every page of my pdf document. This label should contain some info, like the number of report, it's issuing date and the number of each page on the total number of pages, e.g.:
**** Report n 18001-1 of 2018-05-23 - Page 1/23 ****
I'd like to understand if Flexy can take report number and date from some fields (I used file info like object and author in another pdf software) or I have to fill those data into the label (or watermark) typing the whole phrase each time.
Many thanks,
Paolo
watermarks or labels into flexy pdf
Re: watermarks or labels into flexy pdf
You have to manually type these data. I will refer your suggestion to the product management.
- SoftMaker Office 2021
- FreeOffice 2021
