Clear Text Style Formatting
Where can I find the clear text styles?
Re: Clear Text Style Formatting
Do you mean paragraph or character styles?
How do you clear character styles from a block of text? Presumably, to clear paragraph styles, one just applies a different style or chooses "Standard".
- Michael Uplawski
You define a character style which represents what you consider "cleared", then apply it.
Edit: Over 2100 views for this thread? Holy Crap. Are there *sticky posts* on PhpBB?
“Hindsight is in the eye of the beholder.”
