Horizontal Line Display
RCMaddox
Post by RCMaddox »
I haven't found a way to get TextMaker to display horizontal lines relative to text in the way I want. Look at this image: https://1drv.ms/u/s!AgVhuW8u-GbEhk8dHhj0X-LdXLdj
The document on the left was created with TextMaker 2018; the document on the right with LibreOffice 6.03. In the Textmaker document, the distance between the bold "Lorem Ipsum" and the horizontal line is significant and noticeable. In the LibreOffice document, the distance is much less, creating a more pleasing appearance. How can I get TextMaker to replicate this?
Re: Horizontal Line Display
Post by Jossi »
Probably the default settings for horizontal lines in your TextMaker and LibreOffice installations are different. How did you insert the line - via "Object > New drawing > Line"? In this case, just right-click the line, choose "Line properties..." from the context menu and make sure that in tab "Layout" "Text Wrapping" is set to "Behind text" or "In front of text". (If you want the line to flow with the text, position must be set "relative to paragraph" and "Move with text" must be checked.) Then you can adjust the position of the line with the arrow keys (Cmd+arrow key for smaller steps).
RCMaddox
Post by RCMaddox »
Thanks for your reply. I was using Object >New horizontal line. When you create a line that way the right-click Properties dialog has fewer options.
Your procedure does work so thanks for that!
