hi
problem write persian language right to left ?
where is ctl for persian ?
problem write persian or arabic lang ?
Re: problem write persian or arabic lang ?
You have to enable support for Arabic language first in the Options. Then make sure that right to left writing is correctly enabled in the Paragraph settings. Of course you should use a proper Persian font too.
- SoftMaker Office 2021
- FreeOffice 2021
