Audio in Presentations
MRPockets
Post by MRPockets »
Is audio within PPTX/PPT files supported? I'm trying to find a replacement for PowerPoint for a Linux system and it looks like Softmaker Presentations is the best option but I can't seem to get audio files (such as a background song during a timed slideshow) to work.
I found an option to add audio, but even then, I can't seem to get any playback.
Re: Audio in Presentations
Post by sven-l »
Audio is currently only supported under Windows and on the Mac. A sound support for Presentations for Linux is on the wish list.
leirbag28
Post by leirbag28 »
SoftMaker Office is better being BIG in Linux, than very small or unknown in the Windows and Mac World
there is a saying: Better to be the Head of a Mouse, than the tail of an Elephant
Linux should be your main concern.....and I don't mean to make it Open Source and Free...you deserve to get paid for this amazing Office Suite...but it needs to rival PowerPoint...Sound and Video are basic features.
Thanks, I've reinforced the request for audio in Presentations.
iyuvalk
Post by iyuvalk »
Hi. Is the current status still the same? Is there any workaround that I can use?
iyuvalk
Post by iyuvalk »
Also, if I would create a presentation with an audio file embedded in it and would save it as a PPTX file and play it on a Microsoft Office on Windows, will it play?
Yes, in that case you will be able to play that audio in PowerPoint also.
Return to “Presentations 2018 for Linux”
