Service Pack download
DrTeeth
Post by DrTeeth »
Hi,
I like to keep the latest service pack installed locally. However, for the latest one, 928, I cannot find the link to download it. All the links point to here (http://www.softmaker.com/en/servicepacks-office-windows) or here (http://www.softmaker.com/en/download/servicepacks). There are no downloadable links on either of those two pages.
Can you direct me to a working download link?
Cheers
DrT
Re: Service Pack download
Post by sven-l »
The service packs will be downloaded internally via the update function. If you want to store files locally on your hard drive, you can download the complete setup file. It contains the latest service pack.
DrTeeth
Post by DrTeeth »
Hi Sven,
Thanks for that. The thing is that the site gives the impression that they are downloadable. I have downloaded them in the past too.
Cheers
DrT
andyt
Post by andyt »
Dr T. Like you I expected to find files to download and do the update from the website. It does after all have a section called Downloads
In fact my first attempt at using the built in check for updates failed as it went into a loop asking me to close Textmaker to continue. I acknowledged with the OK button but the message kept coming back so quick and top of the stack in the foreground that I could not get the textmaker to close it.
Task Manager killed them all in the end and I came looking for the update file to download.
Thanks your question has been helpful to me.
Andy.
For SoftMaker Office 2018 there is no revision 928. 976 is the latest one.
When you see that message to close TextMaker while installing the update, please close TextMaker first and then click on OK. This was that message will not come back.
