Still having BasicMaker 2018 problems, this with all versions, Beta and shipping...
As of Build 928.0313, keeps coming up with the "classic" Enable40_64.dll not found....apparently the same error we saw in 2018 Beta, because the 64bit port was not done yet.
Is there something missing from the installer, as this file can not be found anywhere on the HDD, no matter how many times SM Office Pro 2018 is installed or re-installed, etc.
Joe Rotello / WindowGroup / USA
BasicMaker 2018 DLL still not found.
- SoftMaker Volunteers
- Contact:
Windows 7 and 10 Pro 64bit | Intel Multi Core i5 3.46gHz | 8GB DDR3 | 1GB Nvidia GTX-650SP @ 1152x864 | ASUS | SoftMaker Office 2021, 2018 and 2016 user
Re: BasicMaker 2018 DLL still not found.
Please use SoftMaker Office 2018 32bit not 64bit if you want to use BasicMaker. We are working on a solution it but currently BasicMaker 2018 64bit does not work properly.
Me too . . . .
Thank you sven-1 for clarifying "lost" BasicMaker
I have been researching alternative Office suites for last 8 months. Softmaker Standard is my preferred choice.
Just downloaded 64-bit trial, your advice to use 32-bit is appreciated and will save frustrations.
