One Window
One Window
One of the most common work processes is to have multiple windows open at the same time for comparison or cutting and pasting between. However, this is not supported in PlanMaker. I'm really surprised that software that is overall well designed like this has such a major design flaw. Any plan of fixing it?
- Contact:
Re: One Window
Click the checkbox "New program window" in File > Open or File > New.
Re: One Window
I am showing no option to switch New Program Window on or off. I am using PlanMaker from FreeOffice 2018. What's up with that?
- Contact:
Re: One Window
SoftMaker Office gives the choice to open documents in tabs or separate windows.
SoftMaker FreeOffice always opens them in separate windows.
