Another UI quirk
seasidepb
Another UI quirk
Post by seasidepb »
A small but mildly irritating thing which I think would be easy to correct (it was happening in the beta in the main ribbon drop downs and you've already put it right there). If I add a paragraph style button to the Quick Access toolbar (ribbon interface, dark theme) the background to the dropdown is dark, making it hard to read the style options until you hover the mouse over each and an orange highlight shows behind (screenshot attached).
I tend to work with the ribbon hidden, unless I'm doing a lot of editing, so the Quick Access toolbar is pretty important to me.
Love the software though - so much nicer to use than MS Office (and LibreOffice sadly has a fundamental problem with font rendering).
jimjutte
Re: Another UI quirk
Post by jimjutte »
Thanks for the comment.
Cheers
Jim
Post by sven-l »
I can confirm the issue. It happens even without the ribbons. I will report this to our developers. Thank you!
Post by sven-l »
The issue has been solved. The paragraph drop down should look much better in dark theme with the next service pack.
