Hi !
I have a Excel sheet that opens correctly in PlanMaker 2018. Unfortunately, when I do a Print Preview / Print, I got overlapped fonts for one of the sheet.
In the attached file, tap "Fiches de partie", the rendering is OK. Do a print preview or print, an issue can be spotted on the screen.
Could you please fix it ?
Regards,
Print Preview / Print issue
- ESMPTT1-LACTT3-R3F.xls
- (148.5 KiB) Downloaded 5830 times
Re: Print Preview / Print issue
Could you please check again with the current Nightly? I opened your attached sample file with the Nightly in openSuse Leap 42.3 64bit and could not see any font issues in the print preview.
Which Linux are you using? Thank you!
Thank you, will confirm later todaysven-l wrote: Mon Feb 19, 2018 10:05 am Could you please check again with the current Nightly? I opened your attached sample file with the Nightly in openSuse Leap 42.3 64bit and could not see any font issues in the print preview.
I am also using openSuse Leap 42.3 64bit.
Regards,
