Hi. I've just been writing a document in Textmaker 2018 and I can't find the autosave function, either on the ribbon or in the Textmaker manual. Where is it please?
Thanks in advance,
CP .
Trying to find the autosave function
Re: Trying to find the autosave function
In the File ribbon click on "Options" and then on the "Files" tab. Here you can configure the autosave option.
It is actually called "AutoRecovery" these days because some customers confused it with the regular save function.
Thank you (and sorry for the delay in responding).
Best,
Colonel Panic.
Best,
Colonel Panic.
