Hello Again
I'm still new to Softmaker and still setting it up ...
Is it possible to set a default folder which will open whenever I hit Save ?
Default folder to save to
Re: Default folder to save to
No, this is not possible. The system (Windows) dialogs are used for the File=>Save as and File=>Open dialogs and you cannot set a default folder here but you can create quick paths which makes it easier to browse to specific folders.
- Contact:
Also, the file dialog defaults to the folder a document was last saved or opened from. From our experience, this is what our customers prefer.
Hello Sven
In fact the Textmaker way is ok, especially as it allows me to see and use all my Windows Explorer favourite folders.
MSOFF
