Table lookup function returns #N/A
allenschmid
I posted this problem for Planmaker 2016. Planmaker2018 appeared to have corrected it but the bug has returned. Sometimes it works and returns the table value, sometimes it returns #N/A. I was unable to get it to work today and had to use OpenOffice. Please correct this. I regret buying this since OpenOffice is free and works better.
- Contact:
Re: Table lookup function returns #N/A
Please provide a sample document that demonstrates the issue. We can then investigate if there is a bug in the software or a user error or a wrong setting somewhere.
allenschmid
I'm attaching a sample document. If it opens and is correct, close and reopen. It seems to be random.
I opened your sample file with several revisions of PlanMaker and used the 32bit and the 64bit versions. I was not able to see the bug. Is there a way to reliable reproduce that issue?
allenschmid
There is no reliable way to make the bug show up. Seems to be about 50/50. I've attached the file saved in xl format. The about information is
PlanMaker Professional 2018 (920.1214) 64 bit.
- payroll18.xls
- (28.5 KiB) Downloaded 4833 times
Please try again with the next service pack (should be available via auto update within the next few days).
