1. Are there backups of the dbf's either used by or created by, also where are they stored?
2. menu's for database confusing and misleading.
example; the database tab... left side first button is.. 'Select Database' but on the right hand side it's Edit database plus a few others. All of which ask for the database to be selected when you perform an action like print labels or print envelope. seems to be a bit of duplication unless there is a reason which is not apparent.
3. Useful if there was a button on the print labels window to quickly save a certain label to be associated with an actual database?
Database backup
Re: Database backup
There are no automatic backups of the .dbf files.Princy557 wrote: Fri Dec 22, 2017 5:35 pm 1. Are there backups of the dbf's either used by or created by, also where are they stored?
Re: Database backup
I will report this as a feature request to the developers.Princy557 wrote: Fri Dec 22, 2017 5:35 pm 2. menu's for database confusing and misleading.
Re: Database backup
Do you think there should be a backup of the database, just for completeness???? Especially as you can actually create a database within the software???There are no automatic backups of the .dbf files.
Regards
Princy557
Princy557
Re: Database backup
I think the user is responsible for backing up his database files. You can use any external backup program to automate that process if you want.
