In past versions of Planmaker, I have always used the following shortcuts:
Insert row ALT+R
Delete row ALT+S
Insert column ALT+C
Delete column ALT+D
I have set these up in Planmaker 2018, however only the Insert shortcuts work The delete ones are non-functional. In the Customise User Interface the correct shortcut keys are shown for each command, but only ALT+R and ALT+C work, ALT+S and ALT+D do not.
Please advise.
Shortcuts
Re: Shortcuts
Have now found that the 'delete row' and 'delete column' commands now only apply to defined tables. Problem solved by selecting whole row or column via the tab at side or top and then hitting Ctrl+-. Not so elegant, but it does the job.
- SoftMaker Office 2021
- FreeOffice 2021
