Does/Will Textmaker support Endnote?
faffy
Post by faffy »
I'd love to leave MS Word behind, however, I am tied to it by Endnote. I write scientific articles and I use Endnote to handle references. That's the only thing that I can't do in other porcessors. OpenOffice and WP are not supported by Endnote. Do you plan to support Endnote or other reference managers?
Do you have any other suggestion?
Csaba
Tobias-L
Post by Tobias-L »
Well, TextMaker 2005 will support references by itself, so you don't need the software Endnote.
Tobias Leißner
erika
Post by erika »
When will TextMaker 2005 be released?
The version number "2005" gives a certain hint... :D
Seriously, the Windows version is in private beta; the other platforms will take some time before entering beta.
faffy
Post by faffy »
Well, you are only partially right. Textmaker 2005 was called 2004 before, yet it was not released that year :wink:
Anyway, I am looking forward to the new version.
Yes, that was before we decided to switch all of our applications to Unicode...
erika
Post by erika »
if you are going to support unicode completely, it makes worth to wait. I would love to see all of the products support unicode as well.
In the first version, we support Unicode Level 1. This excludes right-to-left and complex Asian scripts, but I am sure we'll (have to) add them over time...
Return to “Water Cooler”
